Wiring harness rad fan connector replaceable?
Old Nov 3, 2020 | 07:04 AM
JKJB's Avatar
Default Wiring harness rad fan connector replaceable?
Wondering if anyone knows if the rad fan connector on the wiring harness side is replaceable or repairable?
I noticed theres two yellow plastic pins(in pic below) and am wondering if these are cut off if you could simply pull the connector off and replace with a new one?
One of the female receptacles inside the connector is a bit damaged and causing the fan to work intermittently.
Thx
