Wrangle JK tilt sensor
Old Dec 8, 2020 | 10:22 AM
Polar edtion's Avatar
Default Wrangle JK tilt sensor
Hi I have recently purchased a Wrangler Jeep Overlander Polar Edition 2014 model and now having a problem with the factory fitted alarm system , after setting the alarm the slightest touch to the bodywork or handles set the alarm off . I’ve been advised by a auto electrician the fault is on the Shock sensor or Tilt sensor which ever . Does anyone know where it is located and can it be adjusted ?
Don’t want the Jeep garage expensive costs looking into it. I currently have removed the fuses to the horns and removed the siren to avoid noise for our neighbours so only the lights flash . Any help would be very welcome
Old Dec 8, 2020 | 10:41 AM
resharp001's Avatar
Loved
Community Favorite
Maybe the alarm systems on the models sent overseas are quite different than here in the states? That doesn't sound anything like the factory alarms on mine.
Old Dec 8, 2020 | 10:46 AM
Default Tilt sensor
Many thanks for your reply , maybe the UK models have a different alarm system , hopefully someone may be able to advise
