Rugged Ridge Arcus Bumper Skid Plate Question
Old Apr 30, 2021 | 06:58 AM
dmwil's Avatar
Default Rugged Ridge Arcus Bumper
Edit....
I installed the Arcus today. Looks great and the Smitty XRC fit with room to spare. Next up is a Rugged Ridge steering component skid plate and then splicing the factory fog light wires to reach the new spread out location.
Old May 16, 2021 | 07:25 PM
dmwil's Avatar
Here are a couple pics!
Old May 17, 2021 | 04:59 AM
Dat's Avatar
Dat
If you don’t want to splice, there are plug in extensions, unless you solder the wire then seal, water, road salt, depending on where you are, can be a headache later on, the extensions plug in, no cutting or splicing and seal pretty well
Old May 17, 2021 | 05:01 AM
Dat's Avatar
Dat
Haven’t looked in a while, but they probably run 15 to 25 bucks
Old May 17, 2021 | 03:51 PM
dmwil's Avatar
I agree. I'd love to find those. The issue will be that I'm going from the old style bulb to the newer one, so it would have to be the old plug to the new. Is there a vendor that makes those? I'll get the bulb types and post them when I can, but they are definitely different. I bought new fog lights and they have the newer bulbs. Which is good, though, because the older bulb is hard to find.
Old May 18, 2021 | 05:03 AM
Dat's Avatar
Dat
GM Genuine Parts 19300091 Yellow 10-12 Gauge Wire Splice Sleeve Kit with 10 Splices
Old May 18, 2021 | 05:05 AM
Dat's Avatar
Dat
You may also look into these connectors, they have a low temp solder and a glue in the sleeve that melts and seals after crimping, makes a weather/ waterproof better than heat shrink seal
