hi-lift location
-Here's my setup, I spent 6 dollars on parts for an easy to make Hi-Lift Jack Mount, very cheap and works wonderfully, and even holds a small shovel too. Thanks goes to COUnlimited who came up with the idea, I just also did it.
Supplies needed:
12" of 2"x 1/4" flat steel stock
12" of 1/2" all thread.
3 1/2" nuts
1 1/2 wingnut
Sawzall
Drill with 1/2" bit
Vice
First I started out by removing my spare tire and poping the center cap out of the wheel. Then I cut the flat steel down to 2 pieces 5 1/2" each. Drill a 1/2" hole dead center of both pieces.
Place a 1/2" nut on the end of the all thread, followed by 1 of flat steel plates. You can sandwich the two plates on hole in the factory spare tire carrier. Tighten down the second nut to secure the two plates.
Remount the spare tire and tighten it to the carrier. Add the third 1/2" nut to support the back of the High lift and secure with the wing nut. When you tighten down with the wingnut, you'll press the jack against the tire a bit and that will hold it in place, but the weight of the Jack is actually supported by the 1/2" all thread.
Took me a total of about a 1/2 hour. Jack it solid and swings with rear door nice and smooth. Oh and use a "muffler clamp" for the shovel. And to keep honest people honest, I used a bike lock wrapped around my tire which has a locking lugnut on it, to lock the jack.
Again, credit goes to COUnlimited for this setup!!!
