Lower MPG
It could just be a coincidence, but since installing my CAI (cold air intake) I've gotten roughly 1-1.5 miles per gallon more than stock. You'll also notice that your fuel economy will improve all by itself as the engine breaks in... it took several thousand miles for me before I achieved "peak" MPG.
Now you've done it! You've opened up a can that's been put on the shelf for a while.More power and more MPG in once sentence doesn't really blend. People have been having mixed results with Cold Air Intakes, while others have destroyed their engine with them (Don't go in the water with a CAI).
The best way to get the best economy out of your jeep is to keep the thing stock (No lift... no tires... no bumpers... nothing). Also, be sure to keep it maintained (Regular oil changes, air filter inspections/replacement, tune ups as necessary... maintain the air pressure in the tires). Keeping your foot off the gas helps too. I was getting 20-ish when my jeep was new, but since then I've been a little less friendly with the gas pedal.
Performance-wise, you're not going to get too much out of her. The jeep is nothing more than a paved road friendly off-road machine. It's not really meant to go fast. I don't know what kind of performance you're looking for ("Get up and go"... or "I want to tow") but you're probably only going to be milking some power out of it, and wont see any huge gains.
Guest
Posts: n/a
MPG and performance don't have to be mutually exclusive. The problem is, when you install a part that will increase power slightly and help mileage, generally we like to play with the heavy pedal, and it negates any slight MPG gains.
In general, when you open up the engine's breathing abilities (Intake and exhaust), it doesn't have to work as hard to produce the same level of power. The problem with that is, if you upgrade to a CAI and a full exhaust, you've just dropped two or three grand. Think how much that 1MPG increase will offset $3000 and how long will it take to pay for itself?
