Rustys Off Road Lift
Running the 3.25 kit, all is well. Do order the upper or lower adjustable front control arms so you can get the correct caster adjustment, don't waste your time trying to do it with caster cam bolts, you can't get enough. Ride quality is great, articulation is good and handling is good with the proper caster. Easy install and no complaints!!!
thanks for the heads up...as soon as i get my 600 back from the goverment in a month or two i know who i will be calling... did anyone buy the rustys control arms along with it?
