JScan App & OBDLink MX+ (OBDII Bluetooth)
Old Jan 9, 2022 | 09:01 AM
DominicYoder's Avatar
Default JScan App & OBDLink MX+ (OBDII Bluetooth)
If you are unfamiliar, look up JScan App ($20 license fee) and purchase a MX + OBDII reader ($110).
Many features available to change settings…
Was able to change these computer settings relevant to my needs in less than 10 minutes with no trace left on computer.
2008 JKU (does have a HEMI Conversion)
fog lights “on” with headlight high beams
one touch turn signal
setup LED headlights/fog lights without the use of a flicker module.
tire, gear and transfer case (4.0 Rubicon) ratio change.
Next up… adding rear backup camera!
Old Sep 2, 2023 | 06:37 AM
obguy99's Avatar
Default Rearview on older JK
Did it work? Were you able to add rearview camera with JSCAN? Any difficulties? Thanks! I'm doing same with 2007 manual trans.
Old Sep 3, 2023 | 12:00 PM
obguy99's Avatar
OK. JSCAN allowed me to change tire size and activate rearview camera in my '07 JK manual transmission w 730N removed from a totaled Cherokee (diff to recommend that part because the screws don't line up - serious physical mod needed!. I got the needed "Check your entire surroundings" on the black screen in reverse to tell me it'll work. Used OBDLink LX w JSCAN $23. I think this is all going to work...
BTooth streaming, Uconnect, Sirius, NAV, 2 USBs to HdUnit, AMFM, microphone, HDD, + another 12V unswitched USB for the other cigarette lighter (LOL), will use lockpick for "Auto Front" Camera below 9mph and super stoked for the rearview cam in Reverse as I was not sure this was possible.
