Modified JK TechTech related bulletin board forum regarding subjects such as suspension, tires & wheels, steering, bumpers, skid plates, drive train, cages, on-board air and other useful modifications that will help improve the performance and protection of your Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) on the trail.
Hi, I installed New Fox performance shocks on my 2015 JK unlimited. And the rear bolts on both sides are very loose. I've torqued the bolts to the correct spec but the shocks are still moving.
I bought the jeep used so I'm not sure if the previous owner bent the brackets out. Should I just hammer the bracket to make it tighter? Or just use an impact and try to tighten the bolts more?
I just tightened it with an impact and put anti-seize on as well. My torque wrench was useless so I just kind of visually guessed on how tight it should be.
