Need advice on if the wheels I'm looking to buy will work with my stock Rubicon
Old Mar 7, 2022 | 09:55 AM
ktogashi15's Avatar
Post Need advice on if the wheels I'm looking to buy will work with my stock Rubicon
Hello,
I have a 2016 stock Rubicon and I'm looking to purchase new wheels. I'm currently interested in wheels that have a -12mm offset and a 4.53 backspacing. I also plan on getting tires which are 265/70R17. Could someone explain to me whether or not these set of wheels will work without needing a lift? I'm just not sure if it'll end up rubbing on the front fenders or not.
Old Mar 7, 2022 | 12:40 PM
Jay2013jk's Avatar
Veteran: National Guard
Community Favorite
Welcome to JKF.. The wheels should be fine, actually they should move both the wheel and tire out from stock. I think the OEM size is 255/75 17.. Given the info from the Tire Size Calculator and the offset you are considering you should be fine:
Check this; https://www.calculator.net/tire-size...5&y=16#compare
Old Mar 7, 2022 | 02:56 PM
ktogashi15's Avatar
Thank you so much! I appreciate you taking the time to answer my question.
