Suspension too stiff FT 3"
looking for professional advice from you guys
I am running FT 3" ultimate with HD coils in the front along with FT M Force Gas charged shocks. The ride is too stiff
installed the Rancho shocks made a little difference but not what i was expecting now i think it is the springs which are really stiff i have 12000 KM on the rig thought they will settle down after a while but no luck
have a arb front bumper winch etc in the front
what should i do wait a little more longer for springs tp settle or should i look to change the springs specially the front is really bad you really feel it on every bump
any help is appreciated
I am running Mickey Thompson 35" MTZ with 35 PSI also I have noticed that the left side of the front spring is kind of bent
thats alot of PSI, try to lower your PSI. That'll definetly cause a stiff ride.
I run 26 in my 35's.
Also the spring, the arms may not being adjusted properly, Measure them and make sure they are the same lengths. That will always make your spring bowed.
