Rock Slide Eng. Powersteps with a body lift?
Hi,
I was wondering if anyone has mounted the RSE power step sliders when a 1.25" body lift is already installed on the Jeep?
They are the RSE power steps that bolt to the body then have brackets that connect to the body mount bolts the 3 per side.
once bolted to the body the brackets will then be 11/4" higher than the body mount bolt heads.
I already have a body lift installed, that's why im having an issue..ugh
Just looking for some advice and pics,
Thank you
Thank you
I'm hoping not, they seem to have good reviews by other Jeepers but time will tell, Needing them because Im having health issues and cant climb in as easy.
Thanks
Thanks
Guy I knew that had a different brand step his worked great then one day that Alberta Gumbo/underseal simply plugged it up. He got out they came out and would not go back in when he closed the door. He took that one off in the bush. Best help from this older guy is to use the Grabars (like I do) that easily mount on the inside top corners by the windshield. If you can get your foot on to the mat then you can pull up with your arm for the rest of the job. Real easy.
. Not that OP would be in that position, but it is a really bad habit most folks have.
