Advices on ifts to go with 33inch M/T
Just ordered Cooper STT and 16x8 for my 2dr, now I need your advices on which lift to get. I am thinking a lift between 2~3inch. THANK YOU!
Depends on what you're going to be using your rig for. If you're just mall crawling, stay stock, it won't rub. If you're going to wheel it, then a budget boost would be just fine. TeraFlex, Rubicon Express or Full Traction make decent budget boost kits.
x2: if you are going to run 33s a 2 or 2.5" BB will be fine.
I'll let you know for certain after I get back from Moab. I dont have a lift with
33's right now, and it seems fine from the steep snow hill I climbed up on the other day to test it.
Of course at full flex up on the rocks it might be different.....we'll see. I figure I might need a 1 inch body lift at the most. I dont want any more lift than I truly need. I like to keep the center of gravity as low as possible.
I can get my 33's to rub a little with no lift. But... the truck was twisted to the point where 1 wheel was over a foot off the ground. And it was only a little rear fender well plastic contact. A little spacer on the bump stop would solve it completly. If I had know there was that much room in those fenders I would have bought the 35's.
