Woods Front drive shaft install help
I am attempting to install my new woods drive shaft and when on the phone with woods I was told I need to remove the differental flang which involves removing this big nut. What is required to get this off? I don't want to break anything. I try a breaker bar, but as I pull the flang moves with my pulling (yes the tires are on the ground) and the impact gun doesn't seem to work.
I hope the transfer case is not this hard.
Thanks!
I hope the transfer case is not this hard.Thanks!
this is off topic ... but is this woods off of the forum? like the evap canister guy? lol cause i looked at his site and didn't see the shafts...
EDIT: GOOGLE ANSWERED MY QUESTION
You need to rig up a special tool that goes into a couple of holes on the flange, is about two foot long yet still allows access to the nut. Mopar of course has theirs, but if you have some metal lying around you should be able to rig something up to hold that flange in place. Remember, it's all leverage. Once the flange is secure, the impact should be able to zip it off.
The original drive shaft is already removed.
