3 link front axle mount seperation? GR & Motobuilt combo build
I'm pretty new. I'm not a mechanic but a fair hobbyist. Since I have the time, shop and a decent amount of equipment I decided on a challenging build. I have the option for a 8.75" lower to upper axle seperation or 9.75" which adds clearance difficulty but I can make it work. Build details for reference:
2012 4 door JK w/used XD60's
GR crossmember combo w/towers fr/rr - rear has GR axle bracket kit w/14" king coilovers, bumps etc.. Rear Axle separation is only 8.6"
Motobuilt 4 link rear system w/ 3 link front kit.
Front will be 12" kings, bumps etc...
Just removed a NAG1 w/HD converter & t-case to put in 8hp70 & Atlas
Building to clear 40's
Body off build in progress so if anyone could be helped with pictures I'm sure I could figure out how to add them. Not an easy build using different kits/different people brains of perfection
Boy howdy, it's been a lot of head scratching but getting there. I'm hoping to get some helping opinions here if possible.
@TheDirtman is probably one of few that could give you advice on that. He's around occasionally. I can't be much help here myself.
