Binding issue. Front Axle
Old Aug 10, 2023 | 09:00 AM
BeardsandJeep's Avatar
Default Binding issue. Front Axle
Hello all. Recently I was helping a friend get out of a ditch when I heard a pop in the front end. Now sporadically the wheel seems to bind and make a loud popping noise when turning. I have checked ball joints, track bar, tie rods, and everything else. I jacked up the front. I can turn the wheels and they turn freely from the passenger side. When I turn the driver side it goes for a minute then grabs and turns both front wheels like a locker but its an open diff. If I keep forcing it then it lets go and only turns one at a time again. Any advice?
Old Aug 10, 2023 | 10:07 AM
XJRefugee's Avatar
to start I will throw a wild ass guess out there, could it possibly be a bad ujoint in either front axle drive shaft ? and when turning it binds the "bad ujoint" ?
Old Aug 11, 2023 | 07:41 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Front diff damage perhaps during the tow. Take the cover off and do a visual for bits and pieces. That locking issue is concerning as the diff turns on the highway as well and you don't want locked wheels at speed.
Old Aug 12, 2023 | 04:26 AM
resharp001's Avatar
Loved
Community Favorite
+1 crack open the cover and get a look at the internals. if it weren't for that behavior of appear locked for a moment, i woulda just leaned towards u-joint.
Old Aug 17, 2023 | 02:22 PM
JFish'n's Avatar
Loved
Community Favorite
Check your U joint ends for side to side slop.
I have a replacement Dorman front axle on my driver side that doesn't fully support the U-joint.
I have had a few times where the U-Joint caps get pushed out a little, and then I start getting some of those pops when in 4-wheel drive.
the final tale is a minor vibration at highway speeds, comes and goes.
I need to replace them with something better, but for now I'm looking at a set of safety wire pliers for the next time I center the damn U-Joint in order to help keep the stupid caps in place.
Dorman =
