2008 JK Won't start unless I shift through gears
Any help or ideas would be greatly appreciated. This happens intermittently when I go to start the Jeep, it will begin to crank but will not turn over. If i keep the key on then shift down through all gears (automatic) and right back to park, I can then turn the key off and turn it back on and it will start. I had the starter replaced but did not fix the issue. this seems to be the fix every time, once I move the shifter all the way down and back to park. This may happen once every 2 weeks or on back to back days. No pattern. Thank you for any advice.
