I can’t get rid of death wobble
Old Nov 5, 2023 | 07:59 PM
Papawolf's Avatar
Default I can’t get rid of death wobble
2018 wrangler jk, 35” tires with 4” lift.
Three weeks ago I had a full inspection done because I have been trying to cure a consistent death wobble. The inspection found that I needed a wheel bearing, ball joints, track bar bushings and there is wear in a couple of the adjustable control arm bushings. So I replaced both front bearings, new HD ball joints, inner axle seals, front u-joints and track bar bushings. I haven’t addressed the control arm bushings yet because I can’t find replacements.
everything has been working amazing since the repairs, until tonight! I hit a pot hole at highway speed and it set off a scary death wobble again. Would the control arm bushings now be the cause?
Old Nov 6, 2023 | 05:03 AM
resharp001's Avatar
Loved
Community Favorite
I would start by double-checking torque on those TB bolts. if they are undertorqued even a little bit they can cause issues. 125 ft lbs. Control arm joints are rarely the problem, but I have seen them be a culprit once or twice over the years. In my experience, for a full on wobble, it typically takes 2 issues....either under torqued bolts, bad joints, or combination. Typically with just 1 issue you get some feedback but not a full on wobble. I have trouble thinking control arm joints on an '18 are a problem, but stranger things have happened.
Old Nov 6, 2023 | 05:09 PM
Papawolf's Avatar
im almost at the point of taking the Jeep and trading it in. But I will go through everything again and make sure it’s all torqued correctly.
Old Nov 7, 2023 | 05:44 AM
resharp001's Avatar
Loved
Community Favorite
The one other thing that comes to mind is if the TB bracket hole has wallowed out any from previous wobbles. I wouldn't matter if the TB was replaced and torqued to spec if the hole itself was wallowed and allowing movement.
Old Nov 7, 2023 | 06:01 AM
Papawolf's Avatar
that is something I need to address. I have to inspect that again because it could definitely be the issue. I have done the bolt upgrade but the holes could certainly be oval now.
