35's on stock wheels
Old Apr 12, 2008 | 09:40 PM
Crazyboattower's Avatar
Default 35's on stock wheels
Will a 35x12.50x17 tire fit on the stock 17x7.5 wheel? If so, does it look funny?
Old Apr 12, 2008 | 11:15 PM
BowElk6X6's Avatar
Default 35" on stock wheel
I kept the stock wheels on mine...you will need wheel spacers in the rear to run this setup w/o/rubbing the swaybar. Wheels are 16" but I don't think 1" bigger wheels will look much different.
Old Apr 13, 2008 | 05:36 AM
Chet's Avatar
I think they look fine...ditto on the wheel spacers.
Old Apr 13, 2008 | 05:42 AM
sgmrock's Avatar
I run 35"s, it looks like the JK was meant for them...Don't forget the wheel spacers...
Old Apr 13, 2008 | 05:52 AM
bodybrdng's Avatar
Love mine. But did have to use 1.5" spacers all around
Old Apr 13, 2008 | 05:59 AM
sgmrock's Avatar
Yep, 1.5" are the spacers you want, they do the trick...
PS lookin good
Old Apr 13, 2008 | 08:35 AM
Thanks, that what I was looking for. I like the looks of the stock wheels on my silver JK, and I can save some money. Maybe get some new wheels later. Also, those are some good looking pics.
Old May 20, 2008 | 04:16 PM
Hammer's Avatar
any you guys running 35's on stock wheels ever have any issues? do you fear the tire bead will slip out of the rim? If it's your daily driver what tire preasure are you running for the road?
Old May 20, 2008 | 04:20 PM
TEEJ's Avatar
Talking
Its the opposite....you blow beads when the rim is too wide for the tire...a narrower rim helps to keep the tire on (Within reasonable limits of course).
Plenty of people are running 12.5" section width tires on 7" rims, let alone 7.5", etc.
Oh, and the tire pressure question is like asking what their wife weighs...what one person is happy with has zero do do with what will work for you.
THE REAL KEY...is to look at YOUR TIRE'S max pressure and load capacity (Load range, etc...)...and see how many lb it supports at what pressure.
For a JK, you want to be able to support roughly 1,700 - 1,900 lb per corner...not because the JK weighs 7k lb...but because after calculating tire loading when braking and cornering, etc....that's about what it works out to....depending upon how YOU load it up, etc.
Now, if you get a set of tires that are rated to support 2,200 lb at 50 psi, and some one else gets tires rated to support 3,780 lb at 50 psi....and you ask him what psi he runs...do you think YOUR tires will work at HIS PSI?
Food for thought.
Old May 20, 2008 | 04:27 PM
Yamaha90's Avatar
anybody know how wide the stock 16" steelies are?
