07 JKU ARB compressor w/Terraflex under seat mounting bracket issues.
I have a 07 JKU where I'm attempting to install an ARB dual air compressor using the Terraflex under seat mounting bracket.
Everything so far is going smoothly; however my airbag seat sensors are different than I was expecting.
I don't have airbags in my seat; however, I do have the weight sensors.
Those weight sensors are on all 4 corners between the slider and the lower seat to Jeep bracket.
Those sensors are a good 1in tall, and they mount to the slider via 2 studs/bolts each.
If I remove those pressure sensors the Terraflex bracket mates up just fine, however the lower slider to Jeep bracket won't bolt up unless I break out a drill and mod it.
I'm preparing to just go ahead and mod the fkn thing, but then I'm wondering wtf?
Anyone else have this issue?
I decided to mount the bracket to the seat sliders, then bolt on the airbag sensors, the front bolt I found a washer that's pretty close to the same thickness.
I already have the seat sensor module disabled via jscan since I had issues early on after getting water in the connector.
I had dreams of re-enabling it after cleaning the connector, but I'll probably just do a full delete of the module since I also needed to remove the bracket.
I also ended up taking the seat sensor module and some 3m double sided super tape to stick it to the top side of the teraflex compressor bracket.
Then strapped it down for good measure..
