JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Choosing Recovery Gear
Old Mar 18, 2025 | 09:11 PM
JP_26's Avatar
Default Choosing Recovery Gear
I recently got a winch for my jeep and have been looking into recovery equipment. I plan on getting the ARB tree saver and recovery strap, but I have been looking around at soft shackles and snatch blocks wondering what to get. Most companies like ARB and Factor 55 want $150+ for a snatch block and $60+ for a single soft shackle, on the other hand I have seen harbor freights Apex line at nearly half the cost of other places with decent reviews. So my question comes to this; For someone that will not use the gear very often is the ok to go for stuff from harbor freight or is it worth it to bite the bullet and get a more expensive brand? This is purely a question born out of trying to save some money with the off-road market so saturated and overpriced.
Harbor Freight:
Snatch Block: https://www.harborfreight.com/automo...ock-58175.html
Soft Shackle: https://www.harborfreight.com/soft-shackle-58168.html
Factor 55:
Snatch Block: https://www.factor55.com/p-rrp-stand...-shackle-00264
ARB:
Soft Shackle: https://store.arbusa.com/soft-connec...&lshst=product
Old Mar 19, 2025 | 07:57 AM
AZJeeper's Avatar
Community Favorite
Do you have wire or synthetic rope on the winch? Some snatch blocks don't play well with synthetic ropes. Just something to watch for. Also, if you are running synthetic you might consider a snatch ring (like shown in your Factor 55 link). They can be used with a soft shackle. The downside is they do have some friction on the shackle since it just rubs (no moving parts), but frankly, the number of times the average off-roader needs to double the line or redirect is not enough to cause much wear.
Soft shackles are great, but there are some drawbacks. If you are winching out someone who doesn't have convenient tow hooks, you may have to find an alternate hookup point. You'll need to be really careful not to get the rope or the soft shackle caught on something sharp. I do carry a small length of chain for that purpose, but I'm also very aware that it is extremely dangerous so I take as many precautions as possible to avoid a catastrophic release of the chain. Most vehicles have recovery hooks now so it's been a very long time since I needed the chain. I also carry a spare hitch pin. Suppose the vehicle being recovered has a tow receiver and you are lucky enough to be able to position to recover from it. In that case, a recovery strap can be pushed into the receiver and the hitch pin put in to secure it. Recovered many vehicles that way.
Also, like synthetic rope, soft shackles do lose some of their load rating over time. It depends on how often they are used and how exposed everything is to the elements and UV rays. It's still measured in years so you are good for a long time.
Make sure you have a blanket, heavy jacket, or a dedicated winch line damper to put over the winch cable. If the line breaks the weight on the line will help deaden the snap. Still a good idea to be as far away as possible from the "tension vector" of the cable.
Also, if you do shop for a recovery strap, make sure it's a "kinetic" strap, and not a "tow" strap. A tow strap has little or no give and will likely cause damage if you give a vehicle a tug. A kinetic strap will stretch a bit, soften the shock load, and actually aid in the recovery.
As far as Harbor Freight goes, I really don't have a problem with their stuff. I usually lean toward heavier load ratings for the non-name-brand stuff just to stay on the safe side, but that's just my opinion.
Happy kit building!
Old Mar 19, 2025 | 12:28 PM
JP_26's Avatar
Happy kit building!
I have Synthetic Rope, so i may lean towards Factor 55 in that aspect for a snatch block. I figured the Harbor Freight stuff would be fine for the light use they will get out of me.
Thanks
Old Mar 19, 2025 | 04:16 PM
Jay2013jk's Avatar
Veteran: National Guard
Community Favorite
After watching multipe youtube videos from Matts Off Road Recovery, Trailmater, Casey Ladell, the Harbor Freight equipment is showing up very well along with multiple other companies; and in use in the videos daily on off road recoveries. My advise is watch some ot these before your final decision; you will see the equipment in use
