Will 33x12.5s fit on stock rubi rims?
Will they? Im looking at set of procomp m/ts to replace my stock tires, will the rubi rims mount a tire that wide and are wheel spacers required to mount them?
Yes, they or their metric equivalent (285's) will. Heck, you can even install 35's or taller but the real qustion you should be asking is if they will clear without any rubbing. Now, if that was your question in regards to a stock height JK, yes, 33's will clear as well.
Yeah I know theyll clear, seeing as how im running 32s stock. I just want to go 33s and go wider so it gives the jeep a better stance since im not gonna be able the jump to 35s for awhie.
