What kind of grease do you use?
Was curious what kinds of grease you guys are using for control arm bushings, tracbars, and aftermarket driveshafts.
I was thinking about using that Castrol Pyroplex Blue. Is that good stuff or not?
Since I just retired from a major truck firm. We had independent test run yearly on most available greases made in the world. The overall winner year after year for all combined lubrication, wheel bearings, U-joints, shackle pins, water pumps was Chevron EP-2. Blue in color and has excellent adhesion and water repelency. It is an extreme pressure and high heat, disk brake wheel bearing acceptable. A few instances some of the synthetics were better on one item only but not as good when we considered the complete truck and all of the applications. I use the Chevron EP-2
