front adjustable trackbar support bracket?
I'm planning on adding a Full Traction adjustable trackbar to my lifted JK and it was recommended by a vendor that I add a support bracket along with the new track bar since the factory brackets have proven to be a point of failure on lifted JK's even with the stock track bar. After searching the forum and reading some horror stories of these factory brackets braking I think I will take the vendor's advice and add the support bracket.
Does anyone have any knowledge/experience with these front track bar support brackets? Who makes them? I can't find them on vendor's web sites.
Any recommendations are appreciated!
Thanks!
Thanks!
Yeah. Read this thread.
https://www.jk-forum.com/forums/show...ystery+bracket
I know that's a rear bracket, but if Pro Comp makes one for the rear, I'd say that would be a good place to start.
Thanks for the feedback but I'm getting conflicting information so I'll try to clarify my question. Doesn't the adjustable track bar take care of re-centering the axle? I assume the support bracket that was recommended simply reinforces the existing factory bracket and does not relocate it. Does that make sense?
I have not heard of anybody ripping a factory bracket off with a adjustable trackbar. Most cases you will see is that they have attached a bracket to the factory mount which causes more leverage and rips the bracket off.
Adjustable trackbar is all you need.
But if you really wanted to gussett the factory brackets go ahead it wont hurt.
David
David
