Body Lift w/ 4" suspension lift ?
Old Apr 24, 2008 | 07:25 AM
Zav09's Avatar
Default Body Lift w/ 4" suspension lift ?
I have the Rancho 4" lift, and wanted to get the M.O.R.E 1" body lift. First does anyone have the same suspension lift with the 1" body lift installed( with 35" tires)? Second how is the ride, install, troubles..things like that. And third, where do you get the M.O.R.E body lift?? Any Pics... I have a sahara 4 door.
Old Apr 24, 2008 | 07:28 AM
wayoflife's Avatar
JK-Forum Founder
I have a Full Traction 4" Ultimate Lift and a MORE 1" BL and running 37's without any problems. Install of the BL is super easy but if you have a 6-speed, you will need to trim the inner shift boot.
Old Apr 24, 2008 | 07:29 AM
Zav09's Avatar
I have an auto..so no problems there
Old Apr 24, 2008 | 07:46 AM
Zav09's Avatar
anyone with pics or input ????
Old Apr 24, 2008 | 08:01 AM
kidjeep's Avatar
you wouldn't need a body lift to clear 35s or you could do a 3" suspension or even a budget boost with a MORE body lift to get 35s under there.
I think a 4" suspension with a 1" body lift may look a bit tall for 35s
Oh, sorry , I see you already have a 4" suspension....so why the body lift? Planning on running bigger tires soon?
Old Apr 24, 2008 | 08:10 AM
Zav09's Avatar
i clear the 35s just fine..I wanted to be a litle more taller...but i just wanted to see some pics to see if the 35's do look small with that much lift, im not so sure they would ????
Old Apr 24, 2008 | 08:59 AM
kntr's Avatar
I posted this same thread in the show and tell section about a month ago. There are a few pics there.
Old Apr 24, 2008 | 10:07 AM
Zav09's Avatar
do you have a link?
Old Apr 24, 2008 | 10:49 AM
kntr's Avatar
I didnt get many pics either. Not a lot of guys are running 4" SL and 1" BL
https://www.jk-forum.com/forums/show...ight=body+lift
Check some this thread too.
Old Apr 24, 2008 | 10:54 AM
blockrockin's Avatar
i also would like to do the same . i have a bds 4.5 lift and i would like to add a 1 "more lift because i added aftermarket front and back bumpers and winch so i lost about a inch and i would like to get that back . would the 1 "more lift be the best way of doing that ? thanks
