tranny cooler question
Old Apr 25, 2008 | 07:42 AM
greggradwohl's Avatar
Default tranny cooler question
I am about to install a small additional tranny cooler. From the looks it (and in the instructions) I cut the rubber hose connecting the two hard (metal) lines and splice in new rubber hose for the additional cooler.
I am not familiar with the connections jeep is using here. I would prefer to go directly from cooler rubber to vehicle metal line. Is there any simple way to do this - no splicing rubber to rubber? I.e. some type of connector?
Old Apr 25, 2008 | 07:46 AM
dr.dirty's Avatar
cut the metal line a flare the end and just hook th erubber line to the netal line or do like i did and make your own with the blue and red aircraft fittings
Old Apr 25, 2008 | 08:08 AM
Can you tell me exactly what fittings you used?
Old Apr 25, 2008 | 08:12 AM
paratus13's Avatar
Look at my writeup...
https://www.jk-forum.com/forums/jk-write-ups-39/transmission-cooler-37839/
Old Apr 25, 2008 | 08:20 AM
Thanks for the response. I know this will work. But, this is kind of what I want to avoid - splicing rubber to rubber. This looks a good place for braid to hard line to me.
Old Apr 25, 2008 | 08:23 AM
paratus13's Avatar
Why are you wanting to avoid rubber to rubber? It is quick, painless and works well...no leaks too!
Old Apr 25, 2008 | 08:32 AM
I cant argue. It is, indeed, quick, painless and works well. I just want less rubber and more metal.
edited to say:
Does anyone have any experience doing this? Any more suggestions/information?
