ome question
Old Apr 26, 2008 | 02:55 PM
08 rubi's Avatar
Default ome question
i want to run 35" bfg km2s on my rubicon if i get the 2 inch hd lift kit will i run into any problems even if i have the sway bar disconected? also what track bar should i get?
Old Apr 26, 2008 | 03:00 PM
ChewyGranola's Avatar
I have Full Traction Adjustable Trackbars that I got at Northridge4x4.
I think that you will need 2 in bumpstops with 35s so you don't rub.
Old Apr 26, 2008 | 03:51 PM
wayland1985's Avatar
Northridge has a deal going.... OME with trackbars... not a bad deal.
35's should fit okay, but you probably wont get the same flex as you would with a 3inch lift (Or more)
Old Apr 26, 2008 | 07:57 PM
derekls's Avatar
35s will fit but like previously said if you flex alot you might need bumpstops
FT track bars are nice, and you can get them in a deal package.....
Old Apr 27, 2008 | 05:35 AM
Don-T's Avatar
I have the HD OME kit with adjustable track bars from Northridge. Great deal. I was using 35" MTRs with the OME stuff and I had rubbing issues off road. I did not want to hack up anything on this jeep because every time I did in the past it got out of hand and I ended up with a jeep not very well suited for a lot of highway driving. With that in mind I went to 33" tires and have plenty of room and should still have room when I get the fromt bumper/winch and rear bumper/tire carrier put on as soon as they come in. I am sorry that I went with 15" wheels though, they do not have enough offset, the tires stick out. 17x9 wheels would have been the way to go.
