Installed lift rims and tires
This weekend I installed taraflex 2.5 bb and classic 17x9 with 35" claws fits great but the front has alot of rake I thought that the kit would level this out more, anyone have this same problem and I have my #5 wheel for the spare does anyone know if I can just bolt it to the back my tire should be in today.
I also have a 2.5bb with 35's. I have ordered a front bumper and will probably do an additional .5 to .75" front spacer to level things out. As far as the spare on back goes, if you open the back door and put it on while it's open, you can make it work. My 35's are on stock 17's and the tire rubbs the bumper when it's closed so you have to close it a little careful but not bad over all. It's not moving anywhere. The only issue will be overtime the effects on the door?
I have some pics but can not figure out how to post the spare on mine should fit it is a 5 inch bs so it will be farther out I just thinking here I will let you know in a couple of hours does anyone know how much stock rubi wheels and tires weigh.
