best bang for the buck lift...
in the 3-4" range (not interested in a spacer lift)
Every basic lift I look into suggests addition of control arms, or trackbars, or something else.
I'm just looking for a decent (read: inexpensive) lift where I won't have to spend a ton of money on "extras" yet still retain the ride quality since it is still my DD. Anybody have suggstions?
I got the 3.25" from rustys offroad. Came w/ shocks, springs, and adjustable track bars(both) for about $550. I also added a tera 1" spacer. With that set-up I got 4 1/2" front and 4" rear. I love it and have no complaints.....
I like 3-4 vendors. Right now the Rubicon Express 3.5",FT 3" ultimate, Fabtech 3" and (Vendor x) but it's easier to state what you should have in the kit rather than pick a manufacturer since there are so many good quality maunfacturers. Avoid the kit's with the word economy and you are well on your way to finding a complete kit.
A good example:
http://www.quadratec.com/products/16064_324X_PG.htm
I have to stay at 3" because of state laws but if i could go bigger I would.
Complete kit would include:
Adjust front and rear track bars
new links
Springs
Shocks
upper control arms
New brake lines
Bump stops
control arms and track bars will allow for complete dialing of the suspension as the axles will shift as you go higher and the castor angle will change.
About 2k for a true complete kit in the size your looking at. You need to get shocks to fully appreciate the new travel you will get so skip the Shock extensions.
I currently have a 2.5" BB and noticed I had axle shift and if I went a 1/2" higher I'd need to get adjust. track bars.
I also had a slight change in the angle of the caster and at 3" I would want the ability to adjust the upper control arms as the angle will change enough that it would be questionable.
I'd also recommend a steering stabilizer with a relocation bracket. As a DD it will have a better feel. This will start WW3 but it a personnal thing if you want to eliminate any feel issues. I do suggest adding this 3 months out so that you are sure everything is in alignment and good to go to not hide any issues with the alignment.
__________________________________________________ ______________________
I'm also assuming you are driving a 4dr? If you are driving a 2 door your talking about driveline modifications as the angle will change on the driveshaft. Most shops are recommending this if you go to 3".
Also what do you define as Inexpensive. Some guy's but hemi's in and think it's worth it so is 2k the budget or 3 k. 2700 get's you just about everything you need at 4 inch unless you are thinking a long or short arm kit.
A good example:
new links
Springs
Shocks
upper control arms
New brake lines
Bump stops
Hard to beat the Superlift 4" for the price. I think they're a little more expensive than when they 1st came out though.
I'd suggest adding a set of front upper and/or lower control arms rather than using the cam bolts. You can get by with one set, which will only be about $50 or so.
