largest tires on stock steel rims w/no lift
Old May 30, 2008 | 09:34 AM
berg's Avatar
Default largest tires on stock steel rims w/no lift
I'm not really considering a lift on my stock X but I want to put larger tires on the stock 16" steel rims.
What would be the largest that you would suggest?
I heard that the steel 16" rims are narrower than the optional rims that are offered. Is that an issue?
Old May 30, 2008 | 09:44 AM
RedneckJeep's Avatar
https://www.jk-forum.com/forums/show...74&postcount=3
Old May 30, 2008 | 09:58 AM
berg's Avatar
Thanks, I saw this already but it shows the largest tire on the 17" rim. I have the steel 16" rims.
Old May 30, 2008 | 12:31 PM
Keith615's Avatar
So instead of a 33x10.5 R 17 it would be a 33x10.50 R 16.
In metric that works out to be something like 285/75R16.
Old May 30, 2008 | 07:01 PM
n19948's Avatar
I have 265x75Rx16 and they fit and look fine. I've heard 285 fit but I wouldn't go that tall with the standard gears.
Old May 30, 2008 | 07:20 PM
So, do the math and get the same height/width tire in 16". Good lord.
Old May 31, 2008 | 06:55 AM
cb4017's Avatar
Veteran: Navy
My Unlimited came with the small 16" tires. Within 2 days I replaced them with 32" tires, 265/75R16, on the stock steel wheels. They fit fine with no rubbing.
Old May 31, 2008 | 07:57 AM
berg's Avatar
I didn't take tire math in school. Must be GA redneck thing.
Thanks everybody else. 265 75 16 it shall be
Old Sep 24, 2008 | 11:37 AM
K9Jeeper's Avatar
Good one....Sorry Redneck Jeeper, you had that one coming to ya with your remarks...
Old Sep 24, 2008 | 11:45 AM
armycop's Avatar
If you have no wheel spacers or lift, stick with the 265/75R16.
If you have wheel spacers and a lift, go with 285/75/R16. I used to run this size on a 16X7 rim, which is the same size as yours.
