1 1/4 coil spacers?
Old Jun 2, 2008 | 10:37 AM
Windrocker's Avatar
Default 1 1/4 coil spacers?
I have weighed my bumper / winch combination and it comes in at 210 lbs. Adding that amount of weight on the front drops it 1 and a 1/4 inch. Is it possible to get a spacer of that size?
Old Jun 2, 2008 | 12:36 PM
Big D2's Avatar
What springs are you running?
Yes, a few companies make them. Skyjacker, Rough Country, and Daystar to name a few.
Old Jun 2, 2008 | 06:44 PM
Lorrel's Avatar
The largest spacers I've seen are 3/4". I know Skyjacker makes a set, because I have them on the front of the wifes JK after the AEV front bumper. I do believe Daystar also makes a 3/4" set of spacers. They both run about $40. per set of two. Anything larger, I think you may have to go to a BB and use the spacers from the kit for the front. I did see a few 1 3/4" BB by Daystar, for about $150, and a few 2" kits for around $200-$300.
Old Jun 4, 2008 | 03:32 PM
wrnglrguy's Avatar
Rubicon Express makes a 1.75" front spring spacer...$50 direct from them.
Old Dec 3, 2010 | 12:07 PM
HG07JKRubi's Avatar
They do now !!!
http://www.usaafn.com/products.php?offset=1&id=1
