?? Xenon flares, RC 4" lift, 37's
I have a rubbing issue with my 4" lift and 37's, go figure. I was going to get more lift (1" body lift and 1" spacer) but if I can keep my center of gravity low and get all the clearance I need with xenon flares then I want to go that way. I have already trimmed the body in the rear but what else would I have to trim? Thanks
Here is a couple pics with the new 37's
You're probably hitting that metal bracket where the front upper plastic bracing bolts to. It's not rubbing out back any? I would not worry too much about the CG with raising the body, I was worried about it too until I wheeled again the same places afterwards, technically I realized it raised the CG but practically it was fine, especially if you compensate with wheel backspacing a little. Wish I knew the actual formula to calculate horizontal wheel width stability against vertical height and weight
