Skyjacker 4"
Old Mar 13, 2007 | 06:54 AM
Derrick1's Avatar
Question Skyjacker 4"
I'm just wonder who is running the Skyjacker 4" suspension? I've installed one on my JK 2dr and I was hoping to run the stock rims with GY MT/R's 305/70r17. I haven't installed the new tires yet.
So far, I have installed the lift and I have trouble with the rear swaylinks contacting the rear tires.
will anything else rub before I decide to go with new rims or with wheel spacers?
Old Mar 13, 2007 | 07:19 AM
Derrick1's Avatar
figured out the rear links, I mounted them out board instead of inboard on the sway bar.
they still look pretty close to the tire.
anyone?
Old Mar 13, 2007 | 11:48 AM
woolf's Avatar
SEARCH! You need spacers and bigger tires.
Old Mar 13, 2007 | 11:58 AM
BLKRUBI's Avatar
I'm running the 4" lift, no clearence issues...but my wheels have 5.25" backspacing as opposed to the 6.25" of the factory wheels.
Old Mar 14, 2007 | 03:03 PM
Derrick1's Avatar
I did a search, it didn't work very well at all. I have the bigger tires. I would rather not run spacers.
thanx for the back spacing info BLKLRUBI, thats what I was looking for.
Old Mar 14, 2007 | 03:41 PM
IanUtica's Avatar
I'm runnin spacers at 140 miles a day 4 days a week with no problems so don't be scared to run them!!! They are no different than an offset rim just make sure everything is torqued and retorqued properly. Trust me, I ran an automotive repair shop for 9 years and yes we did tires!! You will have no problems with a quality spacer!!!
Old Mar 14, 2007 | 04:56 PM
BLKRUBI's Avatar
Your welcome, and let me correct myself when I said "no clearance issues". There are none aside from the fact that in a servere turn, the tire scrubs that stupid plastic air dam/skid thing, which is a given if you look through these threads. I plan to trim it anyway before it hits the trail. No biggie.
Old Mar 14, 2007 | 06:19 PM
RedRockJK's Avatar
When you get the spacers on you should be fine.
