Track bar with bracket?
Old Jul 1, 2008 | 05:37 AM
LSU-JK's Avatar
Default Track bar with bracket?
I am installing a 2.5 RC this week. It is only temperary, I will be ordereing a FT 3" in probably around 6 months or less. My ? is if i order a FT front trac bar, do i still need a relocater bracket. Northridge's description of the product says it is good for 2" - 4 " lifts. I really dont want to purchase a bracket for the front If i dont need to but Im just not sure. And will a rear bracket relocater work for me or should I order a rear bar as well now? Rear bracket with adjustible trac bar? This forum has been a huge help in my planning, Thanks.
Old Jul 1, 2008 | 05:57 AM
riverzendz's Avatar
No bracket is needed for an adjustable trac bar. So you'll be set with just the bar.
Now playing: Phil Western - Shimmer
via FoxyTunes
Old Jul 1, 2008 | 06:43 AM
RedneckJeep's Avatar
Word on the street is NOT to use the relocation brackets at all. They lead to breakage of other components.
Old Jul 1, 2008 | 07:05 AM
Bodo's Avatar
Someone correct me if I'm wrong here but it's my understanding that the relocator brackets for the trackbars correct the geometry after a lift. It keeps the trackbar more parallel after the lift.
Old Jul 1, 2008 | 07:32 AM
I think the concensus is that the relocation brackets aren't a good thing. Seems it's better to get adjustable track bars.....that is IF you even need to do anything at all. I hav a 2" BB on mine and it made no difference at all as far as the axles or steering wheel goes .
Old Jul 1, 2008 | 08:18 AM
Ike's Avatar
Ike
the relocation brackets raise the roll center of the suspension, returning the on-road dynamics back to factory specs after the lift. an extended trac-bar can not compensate for the changed roll center, since the pivot point is still in the same place.
fwiw
Old Jul 1, 2008 | 08:20 AM
fwiw
OK, whatever. Do a search and you'll come up with a good number of people who've suffered broken stuff because of the track bar brackets. This horse has been beaten in the ground.
Old Jul 1, 2008 | 08:24 AM
Northridge4x4's Avatar
Sponsoring Vendor
If you buy a adjustabel trackbar you do not need a bracket at all unless you purchase a lift kit that requires a "drop" FRAME bracket like the FT 4" ultimate or long arm drops the trackbar down and still uses a adjustable trackbar.
FT or JKS trackbar will work without any brackets at all.
David
Old Jul 1, 2008 | 08:25 AM
Ike's Avatar
Ike
I wasn't defending any particular product, just explaining why some kits use a bracket instead of an adjustable bar.
I think people should have the information and make their own choices - if you have a problem with that go kick your dog or something.
Old Jul 1, 2008 | 08:55 AM
JeepDog's Avatar
fwiw
Absolutely correct. And we must all remember not all trackbar brackets are the same. I.e. Currie and Clayton...
