newbie lift question
Search the forum and do as much home work as you can.Knowledge is power.FT makes solid lift kits.Look around for some write up's and reviews.If I could start all over and redo all my mods
I would of went with FT.Also take a look at Clayton's kits and Tera Flex as well.If your a wheeler on a budget you also may wanna check out Rustys Offroad and OME.I hope this helps and good luck.
