how wide on an 8 inch wide rim?
can you run a 12.5 inch tire on an 8 inch rim? if i purchase a rubicon i would like to put a 35x12.5 inch mud terrain on the 17x8 mojave teflon by american racing.
will it work?
will it work?
really a 12.5 inch tire on a 7 inch rim? would it make a difference if it was a 33x12.5 inch tire on a 7 inch rim?
i would like to go 35 but do not know if they would be in the budget at this point.
I have the same set of 33 x 12.5's on the same set of 7" rims for ~ 80 k miles now...they are wearing nice, and work great on / off road.....and so do lots of fiends...so, sure 33's, 35's...all good to go.
That's in real life....for off roaders.
If you were a mall crawler/road only person who didn't have any use for a sidewall bulge, etc...generally...for a car...you have the rim width closer to the TREAD width...(12.5" or 305 - 315 mm is the SECTION WIDTH)....but, for a truck/jeep user...you want to have a bit more tire outside the rim, etc.
Tread width is typically a few inches LESS than the section width.
