Would I need to lower my T-case on a 3" lift
Old Jul 5, 2008 | 02:19 AM
Default Would I need to lower my T-case on a 3" lift
I'm getting ready t order a 3" lift for my 07 2dr X wondering if im gonna need to lower my transfercase or get a longer drive shaft or anything like that??????
Old Jul 5, 2008 | 02:56 AM
Bombs671's Avatar
Theres a FAQ about this topic around here try searching.Some say 3" and above you'll need to swap your shafts out for some after market shafts.I don't think you'd have to replace your shafts with 3" of lift.Another way to get around this would be to get a 2.5" lift kit and a 1" body lift.Teraflex makes some great kits as well as Full Traction.Good luck and wellcome to JK-Forums.
Old Jul 5, 2008 | 04:12 AM
Renegade's Avatar
T-cases are not being lowered on JKs like they were on TJs. Driveline vibrations are not a concern due to the use of CV joints instead of universals (except at the front axle). Beyond 3" of lift the risk of damaging a CV becomes a concern and many people change out driveshaft styles in favor of a double cardan type shaft. Good luck.
Old Jul 5, 2008 | 09:48 AM
easttnruby's Avatar
Your fine on the T-case, If you'll be doing decent trailing you will most likely need new driveshafts. Stock ones are shit anyways.
Old Jul 6, 2008 | 08:49 AM
dpoelstra's Avatar
You did ot mention if you are driving an unlimited or a 2 door. Makes a big difference. An unlimited will be fine with a 3 inch lift. More than 4 and many here recomend new drive shafts. I have a measured 4 inches in my unlimited (acheived with 3 inch springs), 14k miles, lots of extreme off roading and no issues.
The 2 door has different angles in the rear because of the shorter wheelbase, and others here can give better advice on that.
Old Jul 6, 2008 | 06:18 PM
lv jk's Avatar
***erator
x2. Welcome to the forum.
Old Jul 6, 2008 | 06:32 PM
dpoelstra's Avatar
Originally Posted by luigi0523
He said " 07 2dr X" In the original post
You sound like my wife..."You never listen!"
My bad...
Old Jul 6, 2008 | 06:44 PM
yea why dont you listen to me when im talking to you.........HAHA just kidding. thanks for the help guys if i do decid to replace my shafts what would be some good ones and about how much do they run again thank you for all the advice
