PowerPlant on LoD bumper install
About all I can say at this point is, the install was interesting to say the least.
These are pic's taken right after I was finished for the night. All thats left to do is wind on the amsteel blue winch line and install the 2" Rustys lift. The front sagged down about 1" with the bumper and winch in place. One nice thing is I sure dont need to worry about someone walking off with my winch. They would have to take the whole jeep with it. There is no easy access to the mounting bolts.
Great job, cool pictures. I just ordered the rear bumper with tire carrier from them and I held up on the front one because of the not yet existing brush guard. I will wait 'till I have the back one installed.
Just one question, I know I can look it up,
is there a remote with the winch?
With all the messing around that it took, I put about 6 hrs into it. There was alot of head scratching to deal with issues that came to light durring the install. No major problems, but it was not exactly a straight forward install.
what was the major problem to install that bumper. That is the exact system that I want on front of mine. Just deciding if I want that bumper or another. Did you have to shim it to fit, if so how much?
I used a angle grinder with a metal disk to cut it back. One more thing is that I needed to mount the bumper first then mount the winch because access to the two inside frame rail bolts, again the pass side is very limited. To be able to get to the winch mounting bolts under the winch plate I removed the front sway bar and disc motor to get better hand position to start the bolts.
Over all I'm very happy with the set up and would recommend it to anyone. It took a little effort to do it, but if it didn't it would not be 1/2 as much fun
