Shrockworks 2-Door Sliders - Small Installation Problems
Old Mar 19, 2007 | 11:54 AM
dougr5150's Avatar
Default Shrockworks 2-Door Sliders - Small Installation Problems
I started to install my 2dr sliders and ran into a couple of small problems.
1. Pass side back support was a little too far back and was getting interference from the skid plate support. I loosened all the bolts and was able to move the skid plate back a little but it is still tight so I will just grind a little off. Picture doesn't really show it well but back of the Jeep is to the left
2. Driver side bolthole in the back was not in the right spot so it was holding the slider away from the frame. It will not sit flush because of a support on the frame but it was holding it too far out. Elongated the hole to fix that.
3. Drivers back support - Once I got the hole fixed I noticed that the slider would hit the tapered part of the skid plate bar and once again push the slider away from the frame. Ground a little off of the corner of the skid.
Over all they look nice and seem very strong, now I just need to take the FedEx tag off and paint them.
Old Mar 19, 2007 | 01:28 PM
Rubimon's Avatar
My plan was to put the slider bracket next to the frame instead of on top of the skid plate brackets. I think the extra space may also help in keeping the drive shaft from hitting the skid plate under full flex which is a problem now. Any thoughts on that. I am putting mine on tonight.
Old Mar 19, 2007 | 03:51 PM
TEXASJK's Avatar
Default 2 door sliders
http://my.project-jk.com/showgallery...rtby=&sorttime
Old Mar 19, 2007 | 04:33 PM
dougr5150's Avatar
Originally Posted by MichaelW
Doug, call Jim at Shrockworks. There apparently is some subtle differences from one JK to the next. Jim already has a plate to fix your gap problem.
They look really good on the 2-door as well!
I was just going to put a couple of large washers in between the rail and the frame to cover the small gap. I understand that there will be some differences it is not a big deal, just wanted to let folks know what may come up and how I got around it.
