Bolt on improved MPG's
Old Aug 20, 2008 | 05:59 PM
Propilot512's Avatar
Default Bolt on improved MPG's
So about a week ago I had some mechs at the unit install Fitch Fuel Catalyst. At first I thought it was total bullsh*t that this bolt on thing could improve my MPG's, but since I drive about 100 miles round trip a day and with gas prices already burning my money I thought F*ck it. Normally I was getting about 16 mpgs around the city and 19 on the highway. Thanks to Tropical Storm FAY I haven't been to work in four days so this is only city driving but I think it works, I get about 26 mpgs on the dash. I have not changed my driving style, I take off at lights and brake hard. Anyone else had any luck or is the dash wrong.
[IMG][/IMG]
Old Aug 20, 2008 | 06:11 PM
TxCop07's Avatar
Vet Army
I have heard about this but dont really know what it is. Care to explain?
Old Aug 20, 2008 | 06:12 PM
MOWrangler's Avatar
I have to admit that I am way too skeptical, so you think you could post again in about 30 days? That is just WAY to much difference to make sense...
Old Aug 20, 2008 | 06:32 PM
I will keep track of my MPG's, I have not filled up and done the math yet, I just going off the dash right now. But I will run it down and then get a fresh set of numbers. I don't know how it works. I got under there and it looks like it connect between the fuel tank and the engine, but I am no Mech so dont quote me.
Old Aug 20, 2008 | 06:33 PM
uup4it's Avatar
Please post some additional info on this...................
Old Aug 20, 2008 | 06:36 PM
Sporticon's Avatar
x2
just my way of making sure I come back and check this thread later for more info
Old Aug 20, 2008 | 06:45 PM
08RedRecon's Avatar
Definitely need fresh numbers as their website says 1-2.5 mpg improvement. Not enough for me topay $196.
Old Aug 20, 2008 | 06:47 PM
Shell's Avatar
The internet is full of infomation if you choose to look for it.
Any new technology brings with it a host of questions. The introduction of the Fitch® Fuel Catalyst to the World market is no exception. In response to claims of improved combustion, increased power and reduced emissions, the manufacturer, Advanced Power Systems International, Inc., has anticipated a few of the more pertinent questions. The following Question and Answer will shed light on what possibly is one of the most exciting innovations of the decade.
Q. Will a Fitch Fuel Catalyst Permanent Fuel Treatment Device affect my vehicle warranty?
No. A properly installed product on your vehicle will not void your original vehicle manufacturers warranty.
Q. What is the difference between a fuel catalyst and an additive?
An additive is usually a chemical introduced into solution with fuel.
Additives must be replenished at each refueling.
A catalyst affects the fuel but does not become part of it.
Q. What is the Fitch Fuel Catalyst?
A permanent fuel treatment for hydrocarbon fuels.
Q. What are the major components of the Fitch® Fuel Catalyst?
The catalyst is a composite of a number of metals formed into an alloy by a propriety process.
Q. How does the catalyst work?
Refineries cannot remove many poorly performing molecules to make a more ideal fuel. In addition, once fuel leaves the refinery or is stored it is subject to attack by oxygen, ozone, and microorganisms (bacteria, yeast, and mold) that grow in the fuel. All these processes degrade the fuel to make a poorer product that prevents engines from performing at optimum levels. The Fitch Fuel Catalyst reformulates fuel prior to combustion on board the vehicle, preventing oxygen and most diseases from attacking the fuel and reversing any degradation that may have occurred prior to the fuel being introduced to the vehicle. The Fitch Fuel Catalyst assists the combustion process by insuring that fuel is highly uniform, potent, consistent, and stable.
Q. What are the benefits to be gained from the use of the Catalyst?
Improve fuel economy
Improve horespower and torque
Reduce emissions
Less carbon deposits in engine
Saves money
Permanently stabilizes fuel
Extend engine life
Less engine and fuel system maintenance
Allows the use of a lower octane fuel w/o sacrificing performance
Q. How is the Catalyst introduced to the fuel supply?
Small engines of 50 HP or less, a small Catalyst unit, called a 'Drop-In', is simply inserted into the fuel tank.
Larger engines either multiple drop-ins or an in-line canister style Catalyst is installed in the fuel line.
Q. What type of engines will benefit from the use of the Catalyst?
All internal combustion engines
Outdoor power equipment
Recreational vehicles
Automotive & Light Duty Trucks
Marine
Commercial Equipment & Burners
Q. How long does the Catalyst last?
250,000 operating miles or 5,000 operating hours
The FFC is a maintenance-free device.
Q. What is the difference between a Fitch® Fuel Catalyst and a Catalytic Converter?
The Fitch® Fuel Catalyst pre-treats the fuel before the combustion process and by increasing combustion efficiency reduces the creation of pollutants.
" Catalytic Converters are installed at the end of the combustion process where they help reduce pollutants after they have already been created.
Q. Why don't the OEMs like GM, Chrysler, Ford, Cat., Detroit, etc. implement the
Fitch Fuel Catalyst on the cars right from the assembly line?
The OEMs don't typically add parts to the assembly line unless it saves money or they are required to add because of specific regulations. OEMs must meet certain standards set forth by the EPA and other regulatory organizations. When determining MPG window sticker numbers, the EPA requires the automotive OEMs to test on a certified fuel such as Indolene. These purest certified fuels are too expensive to mass produce and are not equivalent to what consumers purchase at the pump.
Old Aug 20, 2008 | 06:50 PM
Sporticon's Avatar
"The internet is full of infomation if you choose to look for it."
I spend my Internet time allowance on this forum
Old Aug 20, 2008 | 06:56 PM
VeryApe31's Avatar
WOW Im def. going to look into this.
