Stock Front Driveshaft Life on 3"
Old Aug 21, 2008 | 06:01 PM
Old_School's Avatar
Default Stock Front Driveshaft Life on 3"
So how long can I expect my front driveshaft to last before it explodes like the rear? I am at 11k miles and it is still hanging in there.
Old Aug 22, 2008 | 07:29 AM
SB08JK's Avatar
good question, I have the OME lift and was wondering the same thing.
Old Aug 22, 2008 | 01:02 PM
Fishyguy's Avatar
my stock lasted one day of wheelin I flexed enough to allow the driveshaft to contact the skip/exhaust pipe and it tore the boot so I just had a new one built for me. you can run without the boot if it tears but it wont be long before dirt and grime destroy the driveshaft.
Old Aug 22, 2008 | 02:28 PM
RebelJeeper's Avatar
I got 13k on my front (rear has been replaced) and it's still going strong. BUT, I don't get to wheel as often as alot of the folks on here. So it all depends on how hard and often you wheel it...and even then it may last a while or it may bust the first time
Old Aug 22, 2008 | 02:38 PM
Rubimon's Avatar
Long time unless it's an automatic. Thats what tears the boot. The boot clamp hits on the transmission with your new found flex!
Old Aug 22, 2008 | 03:01 PM
jeepsanddrums's Avatar
I'm interested in this question as well. I will be running the Rubicon in a couple of weeks and am concerned about my driveshafts holding up!
Old Aug 22, 2008 | 03:21 PM
rickl's Avatar
1st trip wheelin after upgrading to 10" travel shocks
Old Aug 22, 2008 | 10:11 PM
wayoflife's Avatar
JK-Forum Founder
if you have a 6-speed, a very long time. if you have an auto, the spline shaft boot is probably already torn.
Old Aug 28, 2008 | 05:17 PM
Old_School's Avatar
I have an auto but I wheel like a wheezer. My boot is still intact.
Old Aug 28, 2008 | 05:44 PM
Alaska-HWY JK's Avatar
Default Front driveshaft boot.
I just had my driveshaft replaced under warranty because they still don't have just a boot replacement. It looks smaller in diameter than the origional. Did they change the design? It has a U-joint on the diff end which I don't remember on the origional. I have a TF 3" lift on and the clamp caught the tranny pan wheeling in Moab in July. The driveshafts had over 10,000km on them and were trouble free to this point. I new the boot would get torn as soon as it saw some serious wheeling and was going to put a different driveshaft up front eventually. Now I have to go look at an 07 front driveshaft and see if its different.
