hella optilux bulbs
Old Mar 24, 2007 | 03:17 AM
nader's Avatar
Default hella optilux bulbs
I found a place that sells replacement 9008/h13 headlight bulbs and 9145 fog light bulbs that are from a reputable manufacturer. I order the 9008/H13 in the Hella Optilux (XP) and the 9145 in the Hella Optilux Extreme Yellow (XY) from rallylights.com. There are tons of crappy ebay ones but I have had good luck with Hella aftermarket headlights and foglights in the past so I thought it was wort a shot.
I'll update when they arrive.
http://www.rallylights.com/hella/bulbs.asp
Old Mar 24, 2007 | 05:53 AM
dsy's Avatar
dsy
I've had real good luck dealing with them.. I'm running the 65w yellowstar bulbs in my fogs from them with no heat problems. A very easy mod to the 9005 bulb and you can use it insted of the 9145. You do have to run a relay to handle the higher wattage but you can do it with just one relay.
http://www.rallylights.com/hella/9005.asp
