exhaust crossover solution???????
Old Aug 24, 2008 | 08:14 AM
Piginajeep's Avatar
Default exhaust crossover solution???????
Does anyone know of any?
I destroyed mine over the weekend, If I can I'd like to change this while its getting fixed.
ID:	12106   Click image for larger version
Old Aug 24, 2008 | 08:24 AM
wayoflife's Avatar
JK-Forum Founder
full traction makes a skid for the tranny cross member that extends in front of the exhaust cross over as well and offers it good protection. while it is made for their long arm kit, i'm pretty sure it can be purchased separately as well.
Old Aug 24, 2008 | 08:58 AM
bly109's Avatar
The rockhard oil/trans skid also extends to the crossmember and it covers the cats too.
Old Aug 24, 2008 | 11:14 AM
RedrockX's Avatar
maybe its just that second pic... but is your drive shaft dented too..?
and those dont look like factory shafts.
OUCH.
cut in a new section of pipe at a muffler shop and get skids.
Old Aug 24, 2008 | 11:27 AM
wiredawg_mg's Avatar
I just ordered the RH skids for the oil pan and t-case after smashing the x-over and denting the crossmember
I hope this puts an end to any further damage, at least in thoses areas
Really looks like you scrapped up the drive shaft as well, same rock cause all of the damage?
Old Aug 24, 2008 | 12:56 PM
Piginajeep's Avatar
Dont say that too loud,. I was using this for a reason to get a long arm kit
So they are only available on the long arm?
Old Aug 24, 2008 | 01:04 PM
Piginajeep's Avatar
OUCH.
it might be? i was planning on having a shop weld in a new piece, the muffler isnt in good shape either.
most of it is just gouges in the shaft, its a JE reel 1350. I dont really need to worry if it's off balance. I have lockout hubs.
Old Aug 24, 2008 | 01:21 PM
wayoflife's Avatar
JK-Forum Founder
no, they were developed for the long arm kit but i'm pretty sure they are an independant piece of armor that you can get separately.
Old Aug 24, 2008 | 01:30 PM
WRAITHYJEEP's Avatar
mopar automatic tranny skid 77$ canadian
problem solved
Old Aug 24, 2008 | 01:35 PM
wayoflife's Avatar
JK-Forum Founder
hmmm, only problem with that is that it's too long and will prevent your drive shaft from drooping as far as it would be able to otherwise.
