Dana 30 Upgraded Need Further Advise
Old Aug 25, 2008 | 12:12 AM
JK07's Avatar
Default Dana 30 Upgraded Need Further Advise
My Front Dana 30 and has the following
ARB Air Locker RD 100 (27 SPLINE)
ARB Diff Cover
C2 Front Axle Reinforcements Gussets
Off Road EVO Front Control Arm Skids
Axle Gear Ratio 4:10
Running 35 MTZ
After doing a search I think the only thing i can chage is Axle Shafts but unfortunately i can only go to 27 spline....So What is the best Axle Shafts I can get?
Is there a write up on replacing the stock Axle Shafts anywhere? I have never replaced shafts before....
Old Aug 25, 2008 | 01:40 PM
jkx0778's Avatar
i'd go 4.88s for 35s.
i got myself some alloy usa chromoly shafts from northridge. they have the spicer 760 u-joint (same ones that come on the D44 shafts). So far so good, but i dont get stupid with the skinny pedal.
i also went with superior aluminum, greasable axle seals.
there is a write up for changing d44 shafts and it's exactly the same for the d30.
good luck
Old Aug 25, 2008 | 04:43 PM
JK07's Avatar
Thanks thats exactly the information i needed. I am gona do a search here to find the write up. But I cant find Dana 30 Chromoly shafts
Has anyone upgraded their D30 shafts?
good luck
Old Aug 26, 2008 | 02:34 PM
jkx0778's Avatar
i got my alloy usa D30 chromo shafts from northridge.... along with my ARB front locker and 4.88 gears & install kits. they are on the website or call david. i got everything pretty quick.
good luck
Old Aug 28, 2008 | 10:56 PM
JK07's Avatar
Do you know what exactly the part number for superior axle seals? On their website the to use Model 30 front axles...... EV33FSL
Is that correct? David does not have superior seals any other recommendation?
good luck
