Here is my JK in Progress
Well it took a while to install my lift one handed (shoulder surgery) and the front bumper is still getting welded up by my father-in-law (didn't trust my left handed welding...hardly trust my right handed welding). But I thought I would share some pics of what I've got so far. First a list of what I did:
1- Rotated the sway bar disconnect motor.
2- Removed factory muffler and installed straight thru muffler in front of rear axle.
3- Cut two inches off rear of rocker guards to give clearance for tires.
4- Bashed in body seam with BFH in front of rear wheel well to give clearance for tires.
5- Designed and built front shorty bumper that uses factory tow hooks and fog lights and mounts my winch.
6- Built temporary rear tow hitch until I finish design on rear bumper.
7- Installed 4 inch superlift lift kit.
8- Installed 17 inch black spoke wheels from JEGS and BFGoodrich Mud Terrains in a 37x12.50R17.
I think that is about it. Here is a few pics.
Medsker
Front Bumper
Lift Kit
Muffler
Rear Setup
Side View
Front View
Medsker
Front Bumper
Lift Kit
Muffler
Rear Setup
Side View
Front View
It's a clip on thing to make the seat belt easier to grab. With my arm being in a sling I put it on. Once my arm gets out of the sling I'll take it back off. I think I got it from Dr.Leanords or some place like that. It's also nice because I'm old and fat and it's hard to twist around for the seat belt but I won't keep it in because of that. It's just too embarrasing to tell people that
Thanks. The mirror is just one I picked up a couple years back from Pep Boys. It came with the arm and everything. I just mount it to the upper black bolt by the upper hinge. I like the mirror because it is slightly convex so you can see behind and your blind spot. I need to pick up a second one for the passenger side though.
Medsker
