2"Rake on Rubicon
Old Mar 26, 2007 | 05:28 PM
JK Hunter Howdy's Avatar
Default 2"Rake on Rubicon
I have a 4" Tera flex lift on my JK 4 door. The problem is the front sits lower than the back. The measurements from the rock rails are 25" in front of the rear tire and 23" behind the front tire. I'm running 35" tires and have a LoD front bumper with a Warn Power Plant. Mark from Tera Flex said I could exchange the 4" rear springs for 3" springs or put larger spacers on the front springs. It has 1" spacers on it now. Should I exchange the rear springs AND put a 2" spacer in the front to level it out? Thank you for any input.
JK Howdy
Old Mar 26, 2007 | 05:36 PM
Renegade's Avatar
I have their 3" kit and used the 1" spacer that was included along with the stock coil isolator up front, and used their new rear spacer/cone without the stock isolator in the rear. Mine sits level with this setup. What did you do with your stock rubber isolators?
Old Mar 26, 2007 | 05:41 PM
The dealer put the lift on so I'm not sure, it looks like the isolater is still there. That is what I thought was a 1" spacer.
JK Howdy
Old Mar 26, 2007 | 06:02 PM
Renegade's Avatar
The Teraflex kits for the JK's have been coming with black 1" polyurethane "leveling spacers." The stock rubber isolators are about 1/2" thick. The Teraflex instructions indicate that using the stock isolators is optional. Either way, this would not make up a 2" difference. Good luck.
