Dana 30 and lockers
Old Mar 28, 2007 | 06:47 AM
greggradwohl's Avatar
Default Dana 30 and lockers
The new D30 uses different gears. I assume this means that the existing lockers will not work for the new 30.
Is this correct?
Old Mar 28, 2007 | 09:39 AM
IGOFSHN's Avatar
According to the Rep for Detroit, the diffs are the same as any other D30, so their lockers are supposed to work just fine. The reverse rotation gears have nothing to do with it. You might have to drill out the bolt holes on the locker because some of the D30 have 1/2 holes and some have 7/16. I talked to him at Tierra Del Sol this month.
Old Mar 28, 2007 | 10:26 AM
Excellent.
Thanks, IGOFSHN
