is anyone running 35 in tires with 410 gears
ive got an 07 wrangler x unlimited with an auto trans and 410 gears is anyone running this settup with 35 in tires and how does the truck do on the road with that gearing , mileage, what rpm at 60mph 65 mph ect thanks for any and all info
I am running 35's, 4:10's, Auto, 2 door and for the most part it is just fine, and i am getting great gas mileage around 21mpg highway. the only part so far I am not liking is steep down hill it does not hold you back hardly at all so it takes a bit of braking. if I remember right the RPM's are around 2k at 60 and 65. I see lower gears in my future but for now it is fine.
It will work fine. My freeway gas millage went from 21 to 18 though....this is without a recalibration of the spedo though. So it still may be getting 21 but not sure.
21mpg? HUH? With 35's???? I have 4.10's and 35's, I keep the overdrive off and run about 2800 rpms at 65mph by the speedo which is off. Overdrive on is gonna bog it to about 1800rpms. I get 13.5 to 14.5 city/ highway doesn't matter. You musta put one of those hydrogenfluxcapacitorthingamabobs
on to be gettin 18 or 21mpg with 35's
Although my wife does have a lead foot and her commute is mostly hills.
Yes I also have the 4:10 gears and 35" tires.
I seem to have no problems around here and some of the hills here are around 8% climb.
Yes its better on the flats and has good pick up,but on the hills NO way would you be able to pass anyone,but I really have no problems.
I did install the K&N Cold Air Intake and that solved the lag in each gear,BIG difference,really they say 8 to 10hp well not sure but feels more to me,still not a rocket.
I'm very happy with the 4:10 gears and 35" tires
I had 4.10's and 35's with an automatic for about 3 months. Starting from stop was ok and driving on flat terrain was good. The slightest rise on the freeway and it would kick out of overdrive and was a real pain. This also made the transmission work hard shifting back and forth. My gas mileage also went down to about 13.5 mpg with my speedo adjusted with the AccuPro. I changed to to 5.13's last month and what a difference. Good power through the gears and the transmission holds in overdrive like I would expect. Gas mileage went up to about 17 mpg with AccuPro adjustment. I think I am still off a little on my MPH, something I will work with the AccuPro. Some examples of my approximate speed and RPM in overdrive are:
40 mph - 1400 RPM
50 mph - 1750 RPM
60 mph - 2100 RPM
Overdrive off:
40 mph - 2000 RPM
50 mph - 2600 RPM
60 mph - 3000 RPM
Hope this helps.
40 mph - 1400 RPM
50 mph - 1750 RPM
60 mph - 2100 RPM
Overdrive off:
40 mph - 2000 RPM
50 mph - 2600 RPM
60 mph - 3000 RPM
Hope this helps.
