Finally saved the $$$$
Old Sep 17, 2008 | 08:44 PM
jasruby's Avatar
Default Finally saved the $$$$
Ok...
So unlike some of you lucky a$$es.... I have to save for this JK piece by piece. I am finally ready to order my lift and have read many many threads on lifts. And let me tell you there is no shortage...
I have decided to go with Teraflex. I don't go offroad a whole lot...but I do some. 80% of my time is spend above 8000 ft in snow and 10% of my time is spent above 10,000 feet and a crap load of snow. I'm don't think I'm too concerned about "flex" but I am concerned about ground clearance. I also park in a parking garage in downtown denver...so overall height is a major concern.
SO... I am looking at a 2.5lift. I am hoping someone can provide some advice on either the BB or the 2.5 full coil lift.
I also want advice on using my Stock tires and 18" Sahara wheels until I have funds for new tires and wheels. Will this look OK for now?
Thanks.
Old Sep 17, 2008 | 08:52 PM
wagonofdoom's Avatar
im not a fan of BB becuase its ghetto as hell.
i have the teraflex 2.5 spring on the way, ordered from northridge 10 days ago or so. it shoudl arrive sometime soon
Old Sep 17, 2008 | 08:53 PM
Ryno's Avatar
Don't be jealous of others. Half the people on this forum are probably in debt up to their eyeballs.
If you're not concerned about flex I would save some coin and go with the spacer lift. It will add some daylight under your Jeep like you want.
Stock tires and a 2.5" lift will look fine.
Old Sep 17, 2008 | 08:57 PM
jasruby's Avatar
OK...but why do you think that? If I am not going to go offroad what reasons would choosing the BB be "ghetto"?
Old Sep 17, 2008 | 08:58 PM
Ryno's Avatar
Hey, guess what Tokyo? I think huge rims on a Jeep are ghetto, so you can shove it.
I have seen many of your posts and the majority of them are negative. Do us all a favor and take a chill pill or two. You might try washing those down with some Midol. K thanks.
Old Sep 17, 2008 | 09:01 PM
Ryno's Avatar
Please don't take advice from someone who thinks 22" chrome rims look good on a Jeep. I've wheeled all over Moab with nothing but a 2.5" Teraflex BB and stock tires and I've never had a problem.
a few reasons
the higher center of gravity, without compensation of a higher spring rate to counter the roll at the higher COG creates a MORE unsafe environment then is already there. shock with a stiffer high speed dampering and a spring lift with a slightly higher springrate would help to counterac the bodyroll inherant in the stock suspension and create an equal or less rollover risk as in a stock setup.
cliffnotes?
Higher you go, the stiffer it needs to be at "high speed" type dampering...IE Swerving to avoid something.
guess what
i dont have huge wheels, so who cares.
Old Sep 17, 2008 | 09:06 PM
jasruby's Avatar
If I decide to use my stock 18" rims and stock tires with the 2.5" lift (either coil or BB) will I need to get the spacers? Or will the teraflex kit include everything I need.
I have ASE certified friends who are just dying to lift my Jeep with me...but I want to make sure I have them help me do the right thing.
Eventually I will be wanting to go with larger tires and possilby different wheels. Like I said I am doing this piece by piece.
Thanks.
Old Sep 17, 2008 | 09:12 PM
jasruby's Avatar
I guess ultimately my question comes down to this.... at northridge there are SIX teraflex 2.5" lift options. Which will be the best for me? and...will I need anything else other than the kit (like spacers) to use my stock tires for now?
