New Lift installed - Questions
Just finished installing a 3" Black Diamond Lift last night. On the initial test drive the ESP light came on a Few times then went off. Haven't drove it much since, but I did drive it some with no issues since. I did recalibrate speedo with Hypertech Calibrator. What are the possible causes? What else should I be looking out for? and Finally....What is the proper way to measure caster?
Thank you, Great site. I have already learned a ton here!
make sure that you recenter your steering wheel and that will probably solve your ESP problem. also, make sure that you have not over inflated your tires. a 35" tire should only have about 28psi in it. regarding caster, you can measure is by placing an angle finder on the base of your axle C or on top of the ball joint. this link should help you out:
http://project-jk.com/jeep-jk-write-...-end-alignment
Will try to re-center.
