6" Rough Country Lift
Old Sep 22, 2008 | 03:49 PM
TxCop07's Avatar
Vet Army
Default 6" Rough Country Lift
Who has a 6" RC lift installed? How easy was the install? How is the ride? Is it a true 6" lift? Any pics?
Old Sep 22, 2008 | 04:32 PM
greenmachine07's Avatar
there are pics on this site somwhere. but it uses 4" springs and 2" spacers
Old Sep 23, 2008 | 03:15 AM
TxCop07's Avatar
Vet Army
is that just for the 2 dr or the 4 dr as well?
Old Sep 23, 2008 | 07:09 AM
Beta-pg's Avatar
I don't have... but have been looking at it, they have changed it to full coils on the rear as well.
After the fat man does his thing at christmas, I do believe I am going to get this kit with the new driveshafts!
I think....but that could change also!
Old Sep 23, 2008 | 11:48 AM
TxCop07's Avatar
Vet Army
So it is 6" coils then
Old Sep 23, 2008 | 12:25 PM
Bunker's Avatar
website says
Front: 6" lifted coil springs, upper and lower tubular control arms, track bar bracket, adjustable track bar, extended sway bar links, pitman arm, stainless steel brake lines, and (2) Performance 2.2 shocks.
Rear: 6" lifted coil springs, upper and lower tubular control arms, track bar bracket with brace, extended sway bar links, stainless steel brake line and (2) Performance 2.2 shocks.
but has a note:
2-door kit includes 4" lifted coils with 2" spacers
so your 4dr will be coils
also note:
• Extended driveshafts are required with this lift.
• Stock driveshafts will not work with this lift.
Old Sep 23, 2008 | 07:13 PM
TxCop07's Avatar
Vet Army
yeah I knew I would have needed drive shafts, didn't you replace yours?
Old Sep 24, 2008 | 05:15 AM
Bunker's Avatar
just the front for now, the rear looks fine. I do plan on changing out the rear though eventually.
Old Sep 24, 2008 | 12:05 PM
fielder441's Avatar
i have it. all coils on mine no spacers. rides good back is a little stiff but its a jeep. it is a true 6 too. i could run 40s with little rubbing i think. oh yea its a 2 door.
Old Sep 24, 2008 | 06:21 PM
TxCop07's Avatar
Vet Army
I would like to see some more pics of your Jeep
